Neue Firmware für GPSmap 60 CSx
  • Info: GPSmap 60CSx - Info
    Download: für 60CSx herunterladen
    Beschreibung (englisch):
    Changes made from version 3.10 to 3.20:
    * Updated daylight saving time dates.
    * Add capability for 2 wide data fields on map, compass, and highway pages.
    * Add capability for 1 wide data field on map page.
    * Added data card information page.
    * Add selectable alarms for proximity waypoints and custom POI.
    * Improve labeling and scanning of custom POI on the map page.
    * Address issue where custom POI finder would erroneously produce no results.
    * Add capability to see vertical profile of an autoroute using DEM topo data.
    * Fixed issue with incorrect dates showing when editing the date field for Sun & Moon page and Hunt & Fish page.
    * Fix issue where invalid find menu options could show when using the Auto Order feature.
    * Fix issue with the Swiss grid providing incorrect coordinates.
    * Fix issue where route names would be converted to upper case during editing.
    * Update data card driver to support SD version 2 cards.
    * Corrected problem with NMEA input that could corrupt Waypoint names in WPL sentences.
    Viel Spaß noch...
    Einmal editiert, zuletzt von MrSpockDD ()
  • Hallo Mr. Spck,
    Danke für die Info!
    Ich habe das Update problemlos durchgeführt.
    Die neuen Features "selectable alarms" und "vertical profile" habe ich aber weder gefunden noch verstanden. Weiß jemand mehr?
    Werner
  • selectable alarms:
    Hauptmenü > Annäherung > Annäherungsalarmtöne
    vertical profile:
    Geht nur wenn Du eine DEM Karte hast. z.B. eine US Topo
    D, A, CH Topos habe diese Infos nicht drin.
    Original von PoPo
    selectable alarms:
    vertical profile:
    Danke!
