I'm italian.
I have a Comand 2.0 into W203 year 2002.
I have bought from German this tv-tunner not original:
What I have need in order to connect it to the Comand?
THANK
Best Regards!
I'm italian.
THANK
Best Regards!
you have dvb-t in italy?
Yes.
IT is works into italy?
THank
http://cgi.ebay.de/Video-Adapt…38851QQrdZ1QQcmdZViewItem
This is goes well?
Does Tv works while drive in my car?
THANK
This is goes well? No !!!!
Does Tv works while drive in my car? Yes !!
What's I need?
THANK
As Holgi wrote: You need Dietz article-no. 1440.
regards
Wenni
thank for your answer.
I need for connect comand + tv free of:
-1 http://cgi.ebay.de/Dietz-1440-…ZWDVWQQrdZ1QQcmdZViewItem
or
Only 1440 !!!!!
the other not so good !
Is dietz 1440 tv-free (car on the motion)
Thank
Very much
Because TV interlock on old COMAND's is handled by the CAN communication between COMAND and TV-tuner this is no issue when you use the Dietz adapter.
The adapter removes no interlock but is a simple FBAS to RGB converter, feeding the video input signal into the COMAND.
It is working also when the car is in motion, but as I stated before, the interlock is not removed. For example if you upgrade to the genuine tuner, that unit is also providing two standard audio/video inputs, the interlock is active again until the unit really will be unlocked by an ODB interlock remove tool.
Kind regards,
MG
http://www.navigeo.de
The vendor of dietz 1440 has said to me:
ME: With Dietz 1440 I can wich tv on the motion?
Vendor: "no, this is not possible, you need another thing"
bad Vendor !! ![]()
