Dear all,
I now have the MD96050 since some weeks and i would like to see some things changed.
I designed partially the following skin, as I think this would help a lot of people.
[Blockierte Grafik: http://users.skynet.be/fa513062/MD/Dreamfox1.jpg]
Things that should be changed:
At night or even during day time, the popping up Blue, green or other colour bar that indicates the next route to take is annoying and takes a lot of the screen. As I tried almost everything, I start to believe that the colour can not be adapted by us, but only in the program. So therefore the following. If you can not arrange easily, then maybe moving it to a more adequate position might maybe help a lot of us.
I think the indication arrow is ok, but small, so I changed it a little bigger
I put the route to take between the two major buttons.
Please let me know what you think of it. Colours and exact position of button can of coarse be changed depending on taste.
I was not yet able to make a skin of it, and I think I will need some help of you guys (or girls) doing that.
What I dont know how to do:
Separate route name and arrow from each other, while it still remains working.
How to add buttons with other functions, (like direct to favourites, stop navigation) as these functions are used a lot! Now you have to go through a complex menu structure.
Thanks for your responses and hopefully help.
