Tach! Ich hatte mir die BT-GPSmaus von Leadtek namens 9553 gekauft und an meinem Notebook betrieben. Das lief auch alles bisher, aber jetzt will sie aus irgendeinem Grund nicht mehr mitmachen.
Ich kann dank des "Leadtek GPS Monitor"s das Problem etwas eingrenzen. Die Verbindung zur Maus per Bluetooth funktioniert nämlich reibungslos und es kommen auch viele Daten am PC an (unter anderem welche Satteliten gefunden werden und wie stark , allerdings will mir das Progamm keine Koordinaten ausspucken. Hier mal eine beispielhafte Log:
ZitatAlles anzeigen$GPGGA,162855.000,5134.9699,N,00708.7721,E,1,08,1.1,108.7,M,,,,0000*04
$GPRMC,162855.000,A,5134.9699,N,00708.7721,E,0.18,173.82,250206,,,A*66
$GPGGA,162856.000,5134.9701,N,00708.7718,E,1,08,1.1,108.5,M,,,,0000*0F
$GPRMC,162856.000,A,5134.9701,N,00708.7718,E,0.08,58.53,250206,,,A*5A
$GPGGA,162857.000,5134.9702,N,00708.7716,E,1,08,1.1,108.1,M,,,,0000*07
$GPRMC,162857.000,A,5134.9702,N,00708.7716,E,0.03,24.54,250206,,,A*51
$GPGGA,162858.000,5134.9704,N,00708.7714,E,1,08,1.1,107.7,M,,,,0000*05
$GPRMC,162858.000,A,5134.9704,N,00708.7714,E,0.11,166.87,250206,,,A*60
$GPGGA,162859.000,5134.9707,N,00708.7711,E,1,08,1.1,107.1,M,,,,0000*04
$GPGSA,A,3,25,20,24,23,17,11,01,04,,,,,2.1,1.1,1.8*39
$GPGSV,3,1,09,20,74,069,28,24,63,289,20,23,58,185,25,17,38,257,27*7B
$GPGSV,3,2,09,11,34,150,29,25,29,067,40,01,27,048,24,13,25,206,*7F
$GPGSV,3,3,09,04,21,304,28*4A
$GPVTG,311.57,T,,M,0.04,N,0.1,K,A*09
$GPGGA,162900.000,5134.9713,N,00708.7705,E,1,08,1.1,106.0,M,,,,0000*09
$GPRMC,162900.000,A,5134.9713,N,00708.7705,E,0.16,7.19,250206,,,A*6C
$GPGGA,162901.000,5134.9718,N,00708.7701,E,1,08,1.1,105.1,M,,,,0000*05
$GPRMC,162901.000,A,5134.9718,N,00708.7701,E,0.19,9.88,250206,,,A*6B
$GPGGA,162902.000,5134.9721,N,00708.7698,E,1,08,1.1,103.7,M,,,,0000*0D
$GPRMC,162902.000,A,5134.9721,N,00708.7698,E,0.20,40.08,250206,,,A*5C
$GPGGA,162903.000,5134.9724,N,00708.7695,E,1,07,1.1,102.5,M,,,,0000*08
$GPRMC,162903.000,A,5134.9724,N,00708.7695,E,0.10,197.61,250206,,,A*62
$GPGGA,162904.000,5134.9725,N,00708.7693,E,1,07,1.1,101.6,M,,,,0000*08
$GPGSA,A,3,25,20,23,17,11,01,04,,,,,,2.4,1.1,2.2*33
$GPVTG,178.54,T,,M,0.10,N,0.2,K,A*01
Ich denke doch, dass da die Koordinaten mit dabei sind (oder?). Warum aber wird das nicht in lesbare Koordinaten umgewandelt, sodass meine NaviSoftware damit auch etwas anfangen kann?
Muss ich das Protokoll anders einstellen? (steht auf NMEA, SiRF bringt auch keine Koordinaten) Oder gibt es ein anderes Messprogramm, um mal zu testen, was falsch eingestellt ist?
Ich weiss nicht, was ich noch tun könnte um es zum funzen zu kriegen. ![]()
