Mio freischalten, Anleitung gefunden,Fragen?
  • Hallo Mein Mio ist da, funktioniert auch alles zufriedenstellend.Nun Meine Frage :
    Ich möchte mein Mio freischalten kann ich nach dieser(leider englischen) Anleitung vorgehen:
    1. Download the installation pack, unzip its content and place it at the root of an SD card
    2. Preparing your computer and the Mio
    a. Insert the CD provided with the Mio in your PC
    b. Using Windows Explorer, select its content and copy it onto your hard drive, say c:\miocustom\
    c. Navigate to the c:\miocustom\Install\Contacts\ folder and rename Contacts.exe into ContactsOLD.exe
    d. Copy the gsfinder.exe file included in customio.zip in this folder and rename it to Contacts.exe
    e. Connect the Mio to your computer using the USB cable (this assumes you have already installed MioTransfer, if not, do it now)
    f. Go back to c:\miocustom\ and double click on autorun.exe, a window appears, click on OK
    g. Click in the "Install" button in the middle (on the "Install Contacts" line) - and after a few minutes you will get the "install successfully!" message - click on OK
    3. Insert the SD prepared in step 1 in the Mio
    4. Unplug the USB cable from the Mio - this takes you back to the main menu - click on the third menu (Screen+Pen)
    5. You are now on the "Contacts" page - click on the first icon - this takes you to a file explorer
    6. Navigate to the SD Card folder in the left window, click once - AUTOMATIC INSTALLATION, see below
    7. In the right window, double-click on Regedit, then do File->import double-click on "SD Card", then double-click on mio.reg, then exit Regedit, File/Exit, this takes you back to the file explorer
    8. Select the windows folder on the SD card then do Edit/Copy, then click on My Computer in the left window and do Edit/Paste and click twice on YES
    9. Copy showtaskbar.exe from the SD card to \Windows\StartUp (Edit/Copy then Edit/Paste) **
    10. Do a reset on the side with the stylus
    11. To access the task bar, click on the bottom of the screen and you can now navigate the menus as you would in your PC
    Voila, you have turned your Mio 268/269 into a full WindowsCE4.2 terminal with the same functionalities as the shipping version(Navigation/mp3/settings), but with the option to install programs such as OziCE for all-terrain GPS or BetaPlayer to watch DivX movies - full list of compatible apps http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=20212 (French Forums)
    AuTomatic Installation - click on customio.cab and move to step 10
    Na ja so ganz hab ichs net verstanden
    Funzt das so? und welcher Betaplayer brauch ich Danke??
  • Na da kommen böse Sachen raus beim übersetzen.Garantie da wird ja nur an der Software rumgespielt.
  • diese vorgehensweise funktionierte beim 269 aber nicht beim +.
    dehlya hats hier erklärt.
  • Hm die Treads hier sind alle etwas durcheinander.Welche Dateien brauch ich den noch um den Mio freizuschalten und den TMPG-Player aufzuspielen.
    DAnke
  • Ok Danke dir dann werd ich mich mal morgen an die Sache machen.
    Sorry ich hab da was verwechselt wegen dem Player.Der heißt TCPMP (ex-BetaPlayer) den ich möchte
  • Da gibt Frank einen Beitrag unter diesem hier den entscheidenden Hinweis: Es geht genauso wie bei den Transonics (Xania DLL Pack )
  • kann mir das bitte nochmal einer erklären für den ohne plus... ich such mich schon dumm und dämlich -.-
    ich kann nich mehr... ich hab jez alles möglich durchprobiert aber das waren wohl alles anleitungen für den mit + aber den hab ich ja nicht...
    bitte helft mir
    ich hab auch auf meine V2 DVD irgentwie garnix was sich nach Conatcts anhört??? ich mach doch bestimmt was flasch
    Original von mimose
    269 = SD Karte und Festplatte
    mit Plus = Nachfolgemodell, Sirf III Chip und neuere Software.
    aha okay ... hilft mir nur leider nicht weiter
    wo finde ich die contacts.exe von der hier die rede ist?
