Indications display with COMAND
  • Io ho installato un COMAND A203 827 52 42 in Classe C,
    I use the radio with the commandos to the handle-bar and I see also in the display under the instrumentation, but I do not see the indication of the COMAND for navigation in the display. What I can make?
    THANK
  • Drive to MB and let set Navigation via Star-Diagnosis to "available".
    regards
    Wenni
  • Thanks.
    I have gone to the mercedes, they has effected the updating (camdio to Comand), but it doesn't work. Thing I can do?
    THANKS
  • MB shall not make some kind of updates, they shall set Navigation to "available" or however it is named in english. Then it will work (displaying Navi - Menu in the tachometer - display).
    regards
    Wenni
