Sorry. And about a Tv Tuner for my Radio?
  • Can anyone tell me how i can install a Tv Tuner in my Radio?Is there any place where i can buy the parts even used to put in my car?
    Where can i find it?
    My radio is a Comand 2.0DX and my car is a W203 C270 CDI of 2002 that i buyed in Germany.
    Many thanks For all your help.
    To the moderators:
    I apologise because of my post of the Cd not copyrighted?
    I don't understand German.
    Thanks for all your help.
    Einmal editiert, zuletzt von ()
  • Moin,Moin,
    @Wenni, wird es übersetzen :D
    Du brauchst am besten den TV-Tuner 220 820 08 97 und dann einen Kabelsatz, entweder original von MB ca. 200,- Euro oder von anderen Anbietern. Das gleiche bei den Antennen, entweder das original Antennenmodul ca. 500,- Euro oder eine TV-Antenne zum einkleben in die Scheiben.
  • O.k. I translate:
    You need a TV-Tuner, the best = 220 820 08 97, additionally a harness, original at MB ca. 200 Euro or from other sources. The same with the antennas, original MB module ca. 500,- Euro or a Antenna-Set for glueing at the windows.
    regards
    Wenni
