hallo, I besitzen z.Z. einen britischen Pionier, den, AVIC-X1, gleichwohl ich meine Maßeinheit des Unterschlupfes AVIC-X1 stehlen ließ, was ich wissen möchte bin, eine hideawy Maßeinheit des Pionieravic N2 o.k. mit meinem Pionier AVIC-X1 headunit arbeitet? $$$BIN ich jedoch in der Lage, meine Navigation für britische Straßen, sowie tuner/dvd zu verwenden? möchten einfach überprüfen, wie ich weiß, ein Kerl, der ein verkaufen und ein gerechtes einige Ratschläge, bevor ich kaufe, er sagten wünschten, daß es Kauf im nicht sicheres 100% funktioniert? funktioniert es? und was ist das diffrence zwischen, WEGMASSEINHEIT DES PIONIERFell-AVIC-X1 und der FELL-WEGMASSEINHEIT DES PIONIER-AVIC-N2? jedermann gefallen advize? danke
it is appreciated that you try to use the German language in this forum.
However, there is a much greater chance for an helpful answer if you specify your problem in English. Give as much technical information as possible (precise model number of all components etc) and describe your question in short sentences.
It also could be very helpful if you would include a screenshot as JPEG.
ok sorry heres my question in english,
hi,
i currently own a uk Pioneer AVIC-X1,
however i had my AVIC-X1 hideaway unit stolen
what i want to know is, will a Pioneer Avic N2 hideawy unit work ok with my Pioneer AVIC-X1 headunit?
will i still be able to use my navigation for uk roads, as well as tuner/dvd?just want to check as i know a guy selling one and just wanted some advice before i buy, he said it will work buy im not 100% sure ?
will it work? and whats the diffrence between the, PIONEER AVIC-X1 HIDE AWAY UNIT and the PIONEER AVIC-N2 HIDE AWAY UNIT ?
anyone please advize?thanks
I am not a Pioneer specialist but I will try to answer your question. In case that I give completly wrong information, someone will hopefully correct that.
To my knowledge, Pioneer introduced the "Blackbox" (hideaway unit) first with the AVIC-X1 since the many functions of this unit could not be housed in one radio-sized system.
If you have proof of purchase for your unit including the blackbox and if you have reported the theft of the blackbox to the police there might be a chance that Pioneer/UK will help you getting a replacement.
