corrupted firmware VNR 9000
  • I am able to buy a Visteon VNR 9000 with a corrupted firmware. Can I fix this myself or should it be done by an authorized Ford dealer? If it can be fixed, how much wil this cost?
    Thanks in advance for your reply.
    A reply can also be done in German, or Dutch.
  • Hi Polleke,
    what kind of car do you have?
    If you have a Mondeo III from 2001 or a Focus (with 1 1/2 Din sice) it is verry easy to fix it for yourself.
    Take out the old Radio, you need radio outtaking tools! take off the cables.
    connect the cables to the VNR 9000 but be carefull, dont make it like the old radio is connected. The positions from the Cables are not confirm with those of the Old Radio. When you connect the cables, look that the small pins (in German Nasen (Noses)) are at the correct position. You can connect them at both sides in the slot. One side will not work! and Maybe demage the Radio. You need an GPS antenna a low price antenne from navishops or ebay is enough. You can connect a secondary antenna but you mustnt do this.
    Hope I helped You.
    Greetings Lordol
  • As software does not corrupt itself, a corrupted firmware points to a defect controller or memory. This can be remedied by reflashing the firmware (this is something only Visteon would be able to do, no Ford dealers have the equipment), if you're lucky you may be able to load it from the map CD. But ... if it has failed once, it will probably fail again. I would not take it unless it was for free. With the issues of not getting any updates (may be on final one this year), the VNR is not an attractive unit for the coming years anyway.
  • I suggest you buy one at ebay, this will be a used part, but you will rafter 1000 or more.
    Software and operating systems are instelled completely and you have no Problems with this.
    Often you have map CD's and GPS Antennas with it.
    Greetings Lordol
