NCDC 2015 in combination with an amplifier
  • Hello,
    Sorry I dont speak German, but I realy want help about this subject. I have a NCDC 2015 in my Corsa C. Now I want to connect an amplifier for adding a subwoofer to my car. But there are no pre-outs ( the white and red thing to connect my subwoofer ). Does someone know wich connection I can use ? Does someone know more info about this subject ? This would be very cool !
    Thanks in advance.
    Wes
  • Hello Yargo,
    sorry, my english is terrible, but I want to try to help you. What you need is a Highpower-Adaptor or a Amp with an built-in Highpower-Adaptor. Then you can connect your Sub via a Amp on the Highpower-Output of your 2015.
    The thing I use now, is a High-Low convertor. Its a small thing that I connect to the existing audio-cables of my car. Is it this what you mean ? It converts 2x -signal into outputs I need for the amplifier. But this is a solution that works, but its far from optimal...
  • Yes, that is what I mean. I know, ist not optimal, but I'm afraid, it's the only way to connect an amp whith a car-stereo, which don't have aux-out.
