unter my products steht folgendes:
Your PDA devices
Please specify your PDA device model(s) from the list below, so that my.navngo.com can check that the updates/upgrades are compatible with your device. You can add more devices if you use your software on multiple devices.
Your specified PDA devices:
* ASUS, MyPal A632 [Remove]
Choose manufacturer and model below to specify your PDA device:
Manufacturer/Model:
Your products
Please specify all your software licenses, that we can offer you as many updates as possible.
Your specified licenses:
* iGO 2006 Europe [Remove]
(CE-6NB6-C7GT-31MZ-11RV-XXXX)
o iGO 2006 Summer Update
(CE-TFCU-L08U-7NPY-R1TK-XXXXX)
Register more products:
If you have more products, please register them by entering their license codes below.
License code: CE-----
und unter previous updates:
Previous updates
Your avaliable iGO My way GPS navigation product downloads are listed below.
* MapLoader for iGO My way 2006 Plus Eastern Europe (205) MB - Download
Updated: 2007-06-20
* MapLoader for iGO My way 2006 Plus Europe (1031) MB - Download
Updated: 2007-06-20
* MapLoader for iGO My way 2006 Plus Hungary (100) MB - Download
Updated: 2007-11-28
* MapLoader for iGO My way 2006 Plus Western Europe (948) MB - Download
Updated: 2007-06-20
* POI-Warner Updater for iGO My way 2006 Plus (3) MB - Download
Updated: 2007-06-20
wenn ich unter my updates "yes, I have a card reader" anklicke, die Größe meiner Card (1 GB) eingebe und weiter bis zu "show available updates" klicke bekomme ich obige Meldung!?!?!
C.
