Kabelgebundener GPS Empfänger von TomTom 3
    habe jetzt mal ein Log erstellt (unten ein kurzer Auszug davon) und kann nur sagen:
    Es dauerte ca. 5 Sekunden und die Sat. waren da.....
    Und im MN6 weiterhin funkstille - Einstellen der Baud und auch die automatische Suche funktionieren nicht..
    LOG
    $GPGGA,094846.689,4710.8165,N,01446.1560,E,1,06,2.5,712.1,M,,,,0000*06
    $GPRMC,094846.689,A,4710.8165,N,01446.1560,E,0.0,000.0,011107,,*08
    $GPVTG,000.0,T,,M,0.0,N,0.0,K*60
    $GPGGA,094847.689,4710.8166,N,01446.1560,E,1,06,2.5,712.2,M,,,,0000*07
    $GPRMC,094847.689,A,4710.8166,N,01446.1560,E,0.0,000.0,011107,,*0A
    $GPGGA,094848.689,4710.8166,N,01446.1560,E,1,06,2.5,712.2,M,,,,0000*08
    $GPRMC,094848.689,A,4710.8166,N,01446.1560,E,0.0,000.0,011107,,*05
    $GPGGA,094849.689,4710.8166,N,01446.1560,E,1,06,2.5,712.3,M,,,,0000*08
    $GPGSA,A,3,12,05,09,30,14,01,,,,,,,3.7,2.5,2.8*33
    $GPGSV,3,1,10,12,78,321,49,05,61,283,47,09,59,141,48,30,42,273,45*7C
    $GPGSV,3,2,10,14,35,296,37,04,24,074,,02,24,114,32,01,15,324,35*75
    $GPGSV,3,3,10,06,11,214,,07,05,217,*7F
    $GPRMC,094849.689,A,4710.8166,N,01446.1560,E,0.0,000.0,011107,,*04
    $GPGGA,094850.689,4710.8167,N,01446.1560,E,1,06,2.5,712.4,M,,,,0000*06
    $GPRMC,094850.689,A,4710.8167,N,01446.1560,E,0.0,000.0,011107,,*0D
    $GPGGA,094851.689,4710.8167,N,01446.1559,E,1,06,2.5,712.4,M,,,,0000*0D
    $GPRMC,094851.689,A,4710.8167,N,01446.1559,E,0.0,000.0,011107,,*06
    $GPGGA,094852.689,4710.8167,N,01446.1559,E,1,06,2.5,712.4,M,,,,0000*0E
    $GPRMC,094852.689,A,4710.8167,N,01446.1559,E,0.0,000.0,011107,,*05
    $GPGGA,094853.689,4710.8167,N,01446.1559,E,1,07,2.3,712.4,M,,,,0000*08
    $GPRMC,094853.689,A,4710.8167,N,01446.1559,E,0.0,000.0,011107,,*04
    Original von MB1983k
    O.K., Empfängerprobleme sind es nicht, im Log ist auch alles drin, was MN|6 braucht.
    Dann kann es nur ein Konfigurationsproblem in MN|6 sein:
    Ich probiers mal rudimentär, ich hab selbst kein MN|6
    Als Erstes Soft Reset, damit der Port frei ist, ganz wichtig !
    dann MN|6 starten
    Einstellungen müßte sein (probier mal die manuelle Einstellung):
    Externer GPS ohne TMC
    Com 1:
    4.800 Baud
  • Das hatte ich eigentlich auch getan, aber ich versuchs gleich nochmal.....
  • Weiterhin FUNKSTILLE.....
    Kann sein das MN6 den TomTom nicht mag....
    Nein, MN|6 "weiß" nicht, welcher Empfänger an Com 1: hängt
    eher, daß MN|6 deinen PDA nicht mag.
    Seltsamerweise ist der X5 "Performance" (wahrscheinlich ist der Advanced mit 400 MHz-Prozessor gemeint), kompatibel, während der X5 Standard nicht kompatibel ist.
    Noch ein Versuch: Ist der IR-Port deaktiviert (Start / Einstellungen / Verbindungen / Übertragen, dort Haken raus)
  • Und, ja der Port ist deaktiviert....
    Naja, schaut schlecht aus, oder??
  • Nö, jetzt warte mal, bis sich jemand mit MN|6 äußert.
    Was Du noch probieren kannst:
    Warten bis der Empfänger einen Fix hat, dann MN|6 starten und automatische Suche.
    Ich meine, ich hab mal gelesen, daß MN|6 den Empfänger bei der automatischen Suche nur dann finden soll, wenn ein Fix vorliegt. Sicher bin ich aber nicht.
  • So, wieder mal zu meinem Problem - diesmal in veränderter Ausführung:
    Habe von einem Kollegen TomTom 6 zum Testen bekommen (der benötigt das zum Glück nicht mehr.....)
    Also Software installiert - eingerichtet und siehe da, der gleiche BLÖDSINN....
    Aber die Software läuft problemlos und ich kann alles machen, nur der GPS ist uninteressant - kann sein, dass die Programme einfach nicht auf den COM 1 zugreifen können??????
  • Hallo MB1983k
    Ich wuerde an Deiner Stelle mal einen Hard-Reset machen. Danach zuerst eins der beiden Programme installieren das nicht geht. Sollte das immer noch nicht zum Erfolg fuehren, dann denke ich mir das Du die jeweilge Hotline kontaktierst. Damit Du nicht zu lange in der Hotline haengst, solltest Du Dir vorher die Kaufbelege zurecht legen.
  • Naja, dann werde ich halt mal ab zur Hotline müssen....
    Nur noch ein letzter Punkt:
    Meine Sicherungsbatterie ist nicht mehr ganz funktionsfähig - aber ich gehe mal davon aus, dass das egal ist, oder??? (mittlerweile sehe ich ja schon fast alles als Problem)
    ... Meine Sicherungsbatterie ist nicht mehr ganz funktionsfähig - aber ich gehe mal davon aus, dass das egal ist, oder??? (mittlerweile sehe ich ja schon fast alles als Problem)
    Hallo MB1983k
    Ja, das ist fuer diesen Fall uninteressant.
    interessante Neuigkeit in dem Fall:
    Hab mal das TTN3 GPS Tool installiert.
    Dann das Tool gestartet und auf Sat. gewartet....
    Danach TomTom 6 gestartet und plötzlich funktioniert es....
  • Will mich ja mit niemandem anlegen, aber ich erinnere mich dunkel ... na jedenfalls Glückwunsch : drink
    @ Bogi: Vielleicht hattest Du das Problem nicht, weil Du immer schön den Upgrade-Weg (TTN3 -> TTN5 -> TTN6) beschritten hast. Bei mir ist das auch erst aufgetreten, als ich mal nach einem Hardreset neu installiert habe bzw. bei Neugeräten :)
    Gruß Jan
    Original von lagoon08
    Jetzt fangt hier ja nicht an zu streiten.... Bis wieder einer ein Auge verliert und dann wars wieder keiner........ :D
    Jedenfalls mal an alle vielen Dank für die Hilfe - war echt super....
