Hallo all, If somebody Can help me in unlock Windows CE in this Becker? Please
Which device?
Please give me more details...so what would you do exactly? -
I have windows ce 4.2. I isn't known on it
Original von mateo886
I have windows ce 4.2. I isn't known on itI'm sorry but I dont know what you mean?
Sure you have CE 4.2 and now? I didn't understand your second sentence!
Maybe you can use an english dictionary to explain me your request?! -
Er möchte wohl wissen, wie er das wince beim 7916 freilegt, um z. B etwas anderes aufzuspielen....
I want unlock Windows Ce to instal some Navigacion program (MioMap or TomTom)
Hi mateo,
go to "Settings" --> "Information" and there you can find the logo from Navigon.
Click several times on the logo and you will see... WIN CE.Regards
MrU
MrUndercover BIG Thanks, it's working but I have broken down USB port in Becker and I cant instal Nothing
Oh that's crap. Sounds like an expensive problem. Now you must send back the unit to Becker and they will repair or change. Wish you good luck and a low invoice.
If you have any further questions do not hesitate to ask us.Regards
MrU
Edit: Hey mateo
Why do you need the usb port? On the bottom side of the unit you will find a serial connection, behind the small cover! And in scope of delivery there was a cable with the right plug to this port. After connect, your computer recognize the device as a card reader or something else. May this is a help for you?
Unfortunately, It Isn't working
Sorry for that
Hallo, I Have repaired USB port, Now How I can unlock widows CE and instal TomTom
Original von MrUndercover
Hi mateo,go to "Settings" --> "Information" and there you can find the logo from Navigon.
MrU
