have installed comand the 2,0 A203 827 52 42 into Mercedes Class c Sportcoupè. My car is CAN-BUS, the COMAND is not CAN-BUS. T
he command to the handle-bar do not work and the display does not work.
HOW I MUST MAKE?
THANK
You have a plug formerly installed at your Audio 10 but not applicable at your COMAND, this plug is named plug C.
You need a C2 - plug, part-no. 000 545 42 30 + 001 545 48 40, additional two pins 008 545 55 26. And then connect:
From existing C pin 1 to new C2 pin 9 (CAN high, brown-red)
From existing C pin 2 to new C2 pin 8 (CAN low, brown).regards
Wenni
where I find it?
The parts you find at your Mercedes - Benz - dealer....
regards
Wenni
Therefore I resolve the problem to the display, that is I succeed to see the navigator on the display?
I don't know which kind of problem you have with the navigation. For having it working you (and the system) needs:
- an inserted navi-CD
- a GPS - Satellite-Fix for having the momentary position (prerequisite: A GPS-antenna has to be installed)
- Speed-Signal (via CAN-Bus).Ignition On/Off, Dimming of Dash-board-illumination, Outdoor-brightness, Steering-wheel-remote and info's for tachometer-display are coded in CAN too.
regards
Wenni
P.S. It would be very helpful you don't split up any new question into a new thread, I don't like it to look into threads posted weeks ago for getting informations about your configuration.
