Hi i am sorry i can not speak german i have a falk f series navigation device whenever i start it, it resets and i can not connect it to computer is there any advice ?
Hello,
first of all, it is necessary to break through the start loop, so that the navigation device can successfully be connected to the Computer again.A "special" start file on an SD card will allow that.
This start-file will not be able to fix the originally problem, because it’s just a “dummy”. But it’s really good for breaking that horrible start-loop. After the usage of the file, a reinstall of the navigation-software is still recommended, and now you should be able to do it with the “Falk-Navimanager".
Here is a short tutorial:
1. Create an empty(!) text-file with "Windows Notepad" on your computer.
2. Store this file and rename it as “AutoRunCe.exe”.
3. Copy this file onto a SD-Card that fits to your navigation device.
4. Put the prepared SD Card into the Card-Slot of your device and hard reset the device by using the sliding switch (OFF/ON).
5. Your device will start with an empty screen, you will just see a Falk typically picture as background.
6. After that, reconnect your device with the computer and install the original software of the navigation device by using “ Falk Navimanager”Greetings
>>>Edit: I apologize for my bad English<<<
Hello,
Thank you buddy it works finally thanx for advice
